I go straight from the relay output of the micrologix 1000 to the solenoid(0.69 amp on the coil rating to be exact) using the 889V-LA2DBE-5 (AB varistor surge supressor din valve cable rated for 120 vac). So I am surge supressing at the valve with the built in din connector. Havent had the problem since I put the Isolation relay in yet, but it arcs like crazy so I know its a matter of time. Is it maybe something to do with the "varistor" surge suppression? I need to get rid of the arc somehow when im shutting off the relay
