Micrologix Analog Value Storing (Min, Max and Average)
Here is my example: I'm sure there are a lot of ways to do it
I am using
F8:0 as pH SCALED
F8:1 as pH Max
F8:2 as PH Min
F8:3 as pH Average
F19:0-F19:5 as 6 days of pH Max
F20:0-F20:5 as 6 days of pH Min
F21:0-F21:5 as 6 days of pH Average
I didn't run on Emulate yet, Flow & Temp would be the same just address changes
Rox I'm having some issue how you're determining the sample rate on the EQU with the RTC. I never see the ctu advance and I'm not sure how you're accomplishing the sampling.
I'm running it on the emulator
Thx
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
676
Hello everyone.Am new in allen bradley configuration,i have a mini project to execute, i have wired my Micrologix 1400 for analog input signal of...
1,508
2,614
Hi All, I would like to ask you if possible to have some samples code for the realization of a software filter to be used in a PLC Micrologix...
2,095
All, I need some assistance ASAP. I am not sure how to configure IV3+ analog input for 0-10 vdc. Is there a jumper or something that I need to...
1,399
