missing cross reference Inputs on screen
mulderm
Jun 2003
Netherlands
298
Hello,
I have using RSLogix5 V 6.1.
I have selected by view->properties->address display
the cross reference display with Inputs and Outputs
see on rung on the sreen.
Problem is that I can see all the cross referenceon screen, but
not the cross reference from the Inputs.
Example: no cross reference by I:000/00.
Who can help me?
Thanks,
mulderm
No Input Coils
The two checkboxes are a cross-reference for coils.
The second box ("Display Cross Reference for Outputs on Rung") will display at the coil, and list where the contacts are.
The first box ("Display Output Cross Reference for Inputs on Rung"), which is the one you checked, will display the rung of the coil associated with the contact. It doesn't display where all the other contacts are - just the coil.
For your inputs (such as I:0/0), there is no coil (at least in logic - one could argue that there is a coil in the input module). Therefore, you don't have any information in your cross-reference
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics show not only blower...
108
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
92
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
302
Hi guys, got one problem PLC model fp-xh c60t and HMI model TG765S-MT I've encountered an issue which is the recipe file went missing if i swtich...
88
I have a modicon quantum plc and and i have a stu file that have the program but when trying to download it to the plc. it gives not built and...
83
