Missing Feature from FactoryTalk View ME
curlyandshemp
Jul 2005
Toronto
1,903
I think a very useful feature is missing from ME studio that is present in Panelbuilder32. In PB32, the Tag editor gives a Tag Count feature. I cannot find any such feature in ME Studio.
This just cost me having to leave our company bar-b-q to travel to an out of town jobsite to reinsert an HMI tag on a screen that I had deleted yesterday. I have inherited an application, and was cleaning up redundant tags from the HMI tag database and inadvertantly deleted 3 tags used on one PV+ page that the customer tried to access today.
I could have downloaded the corrected application via dial up modem, but I could not risk chance of corrupting the existing app if the download failed due to poor phone line quality.
Bottom line, is there any way in ME Studio to cross reference an HMI tag?
You have two manners to do a Tag search in ViewStudio ME (both methods can only search a tag in a single display, so you have to repeat your search for every page):
1. Select all the objects in a display (CTRL-A) and activate Tag Substituction (CTRL-R); then you may enter the name of the tag you need to search in "search for" field. This method doesn't give you the ability to know in which object the tag is used...:(
2. Another way is to use the Object Browser (right click on a display, select Object Explorer); click the "highlighting on " checkbox and, after that, the settings button.
Check "By Tag Name" box and select the tag from the list.
If the tag is found on this display, the object will be highlighted.
- [font=comic sans ms,sans-serif]fuzzy logic[/font]
Go to the Rockwell Knowledgebase and search for Project Documenter. This utility is only for v5.0 of SE/ME and can provide cross-reference info on HMI and Direct Reference tags.
OG
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics show not only blower...
126
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
109
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
311
Hi guys, got one problem PLC model fp-xh c60t and HMI model TG765S-MT I've encountered an issue which is the recipe file went missing if i swtich...
89
I have a modicon quantum plc and and i have a stu file that have the program but when trying to download it to the plc. it gives not built and...
84
