Mits GOT1000 over ethernet
Critt
Apr 2006
Ontario
153
Hello everyone
I have a QJ71E71-100 ethernet module to talk to 3 GOT1000 over ethernet. I have the IP addresses in the screens setup and configured for ethernet, ethernet cards in the GOT's. They are all plugged into a router. The GOT's ethernet light is on but the qj71e71-100 card has the run light, init. light and the 100M light green but no lights on the rj45 port. Do I need to write some code to make the screens talk to the card?
Not sure about got but you have to at least have a protocol set in the ethernet card, you do this by settings in gx developer & suggest the melsoft protocol is the one to use.
There should be at least some info with Got help files I would think.
Check out the mitsi website for manuals Got & Q series.
Hello, I'm trying to create a faceplate that features a bar where a real PLC tag is passed through the faceplate interface. I want to check the...
337
We're converting a SLC 5/05 to 1769 CompactLogix. The existing PLC is spread among two cabinets, with five racks total (last two racks being read...
1,646
Hi, Is there an easy way to limit the input tag by using min and max tags from the PLC? Thanks
1,281
Do people typically use both end limit sensors and configure soft limits for linear servo axes? I thought this was standard practice until one of...
5,809
Kindly at which temperatures are the servomotors ok to run? We are trying a machine for long periods, and some of the servo drives displayed a...
2,436
