Mitsi Q /FX3U
cjd1965
Apr 2007
UK
1,659
Hi
I am looking into using a Q as master and a lot of FX3U slaves over ethernet. I need to read the manual but....
Can I broadcast data from the Q to each FX , and return data from the FX to dedicated memory areas in the Q for each FX.
It would be a max of 100 digital and analog values per FX.
I realise I may need to hardcode IP addresses to acheive this
Hope this makes sense.
U have to configure the IP address in Q CPU and have to write some basic programs in FX to read the value.
Can some one please tell me how to connect the two items above. So far i have random data in my (d) regs on the hmi. And its all the same number...
1,060
Connecting a E1071 to FX3U via cab19 cable.....connection horribly slow and HMI keeps freezing! Any advice?
1,457
I have a new application where I am adding a linear transducer and ethernet to some torque stations. The question is does it matter what order I...
2,914
We've got 2 cooling fans on our system. They switch on based on water temperature. One switches on at 25c. The other switches on at 30c. The code...
3,081
I have a siemens 317-2 and an old GOT1000 (GT1675M - V) I am trying to get the darn things communication and having no luck. I have followed the...
2,216
