Mitsi Q Network HELP
yorkypaul
Oct 2007
Leeds
I have inherited a Mitsi Q series rack with Q00 CPU and a QJ71E71-100 fitted.
What's the quickest/easiest way to set up IP address and start talking to it?
Thanks,
Paul
You need to go into network setup (gx developer or IEC) & configure either melsec, tcpip or udp links.
set the required parameters in the hardware setup, download the hardware & power off & on to cold boot.
It will depend on what you are going to use to chat to it what protocol & setup you use.
A tip if you are using kepware, then it don't like tcpip use udp, well on the kepware side, I found that you can have anything in the ethernet card & it still talks.
The IP address is set in Network Parameters in GX Developer or GX IEC Developer. You need to connect serially and download the parameters, then reset the PLC and you should be able to talk to it. But the port settings which need to be made in the Network Parameters will vary based on what software on the PC you plan to use. If you're looking at programming software like GX Developer, set one connection channel to MELSOFT connection and you're all set.
Installing a QJ71E71-100 onto a rack with Q00 CPU. What's quickest/easiest way to set IP address and start talking to it? Thanks, Paul
1,764
We've got 2 cooling fans on our system. They switch on based on water temperature. One switches on at 25c. The other switches on at 30c. The code...
3,081
I have a siemens 317-2 and an old GOT1000 (GT1675M - V) I am trying to get the darn things communication and having no luck. I have followed the...
2,216
Hi all, I'm not all that clued up on GX Developer with A series CPU. I have an Ethernet module A1SJ71E71N3-T and for the life of me I cant...
1,416
Hi, I am trying to communicate with a Mitsubishi A2A CPU using a MEDOC SC-03S2 interface, my Mitsi. programming software is MEDOC V2.30 For some...
1,831
