Mitsu FX3U Encode instruction
pacak
Sep 2006
Arad
65
Hi!
I am fighting with this instruction inside a GX Developer project.
It does not work and I get an "Operation error" message (err. code 6706).
Looks like this:
-----/M8000/------------------[ENCO M310 D40 K7]
What could be wrong?
I've tried also with K1, same result.
I'm new to Mitsubishi so please bear with me. Thanks!
The instruction works fine at least with the FX range.
The instruction as you've programmed will look at the status of the bits M310 to M317 and write the most significant bit position that is active to D40 (ie - if M311 is on then it will write 1 to D40, if M310 is on and M312 is on then it will ignore M310 and write 2 to D40)if M315 is on then it would write 5 to D40.
I hope this helps,
Steve
Hi!
Thanks for the answer!
After a couple of program downloads it works right now (if there is a bit set in the M range, there is a non-zero value in D40). Before that D40 had 0 in it.
However, I still have the error message (see attachment)
According to the documentation, if I use a bit device as a source, then the instruction can monitor 2^n M devices (in my case 2^7=128, so M310-M438).
You are right, it would be 2^7 bits which would give 128 bits, so actually it would be M310 to M437 not M438
As for the error message I have no idea, I don't get any error, which processor are you using?
Steve
Hi guys, I'm having a problem on how to save the home position for omron servo driver. How does the servo driver know where the home position is...
2,415
Has anyone had experience interfacing with serial comms a FX3u and ABB ACS850's drives?
2,192
Hello everybody. I encountered a problem - I don’t know how to update the firmware on the Mitsu MR-J5-40G-N1 (ethercat) servo amplifier. My...
406
Hello to Mitsubishi Electric experts. I have been tasked with developing an application that gets data from a MELSEC application, using MX Sheet...
1,258
This is my first on the job exposure to messing about in a PLC with a PC. So far it hasn't gone too bad but I'm having a problem and it all...
2,632
