mitsubishi a1sh write mode
how exactly you are conencting? SC-09 to CPU port or...?
what port is on your PC side? COM1?
are you sure you actually connect and go online?
ou can check (and change if needed) connection settings under
online menu, Transfer Setup. There is button to test connection.
panic,
i'm connected with an sc-09 and com1.everything is ok with my connection, i can go online no problem.i just can't seem to get into write mode, the option is greyed out.i checked the mem protect switch on the cpu,option settings in gx dev are ok,i do a verify before trying to go in write mode and still nothing.i'm starting to wonder if the version of gx that i have is limited to read only.
cheers
i figured it out.when the software was installed they installed it so no program editing is possible.this is a great safety feature for maintenance departements.i just reinstalled and all is well.
cheers
Hi All, An old "Mondial" push button panel died on me forcing me to use a TP177B with an A1SH CPU using the A1SJ71UC24-R4. I have tried to wire...
2,096
Hello This morning when I tried to download my program to my mitsubishi A1SH CPU I got message Enter Keyword. The funny thing is that i have...
3,070
Hello. Im trying to download my PLC program from Gx Developer to a mitsubishi A1SH controller. But i dont manage to establish connection with...
6,438
Hi Can someone tell me how I best can get to A1SH on Citect. The A1SH is connected to each an E700 terminal from Beijers. At first I thought...
3,227
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
43
