Mitsubishi A800 VFD for Standalone Motion
JRoss
Sep 2006
Dillsburg, PA
184
Has anyone used the Mitsubishi A800 VFD with encoder card as a standalone motion axis? I'm looking at upgrading some Danfoss drives*with SyncPos motion cards for a customer. I can go full bore and replace the drives and motors with servos, or I could attempt to just replace the drives and leave the original motors and encoders for about half the cost.
Why not use a Yaskawa A1000 I know that they can be used to replace servos
I have done that many times
They actually have an option software package to exactly what you want
In a word: familiarity. I have all the software and know all the players. I've been working with Mitsubishi hardware for 14 years.
I'm also considering control techniques for similar reasons.
The couple of times I touched Yaskawa servo drives, I wasn't particularly impressed with the ease of use, so I'd hesitate to go that direction. That said, I know they're a major player in the drive world. Who is the local distributor?
I understand familiarity it's always easer to work with what you are used to.
I have worked on a few Mitsubishi and have found then lacking, but it all about choices.
I have been working with Yaskawa since the mid 1990's been empresses with then, features and reliability they are always years ahead of the development curve.
What is the application? The A800 series VFD does have motion control capabilities but it does depend on the application, you're not getting coordinated motion without some form of external control (or using the onboard PLC)
As the the overall concept, an induction motor + encoder is not going to be capable of the same acceleration profile as a servo motor, because (assuming permanent magnet type) the servo motor has less inertia, leaving more of the torque that can be used in the application. There is little to no difference in the drive technology, other than the more complex firing algorithm needed for the PM servos, that's why many of the high-end VFDs are capable of either/or. So if your application is using IMs with encoders and is doing what is required, there would be little justification to change it to servos now.
The Advanced Motion Controller in the Control Techniques M700 has virtually all of the functions of the Danfoss SycPos Card, plus more.
It's not as easy as Power Tool Pro / EZ-Motion, but there are a bunch of examples and good tech support to get it going. Get ahold of your local Sales guy there, and he can get you hooked up with the right support.
Long time reader first time poster, I will try to keep it short but there is a lot of variables here. I have a Mitsu A846 running a 1000 ton...
4,132
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
94
Hello I am writing to request assistance with obtaining a specific GSD file for our Mitsubishi inverter type A800-E, which is connected to our...
431
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
47
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
41
