mrtweaver
I have been trying to look thru the mitsubishi data that I have and well I dont seem to be having much luck so I thought if I posted a mitsubishi command here someone might be able to tell me exactly what it does.
The Mitsubishi PLC in question is a FX1N-24MT
The command is:
----(SPD X000 D130 D10)--
I am assuming by what I do know that the end result of this will be stored in D10, but exactly as to what this command does I have not been able to find out. Any assitance greatly appreciate.
Also if you want I have attached the program to this post. What I am trying to do is find out what math is being used on input X3 so that they can display the speed of the machine in Feet Per Min. If you can see exactly how they are accomplishing that and what formula they are using I would appreciate you pointing that out as well. Thanks again and to all have a great day and a wonderful weekend.
The command is:
