Mitsubishi Conversion A to Q
zai_jnr
May 2008
MALAYSIA
169
Hi All,
I'm now try to check and study conversion adapter for AX82 to change to QX82 (64 input type)... Normally for 32 and 16 I/O, there have conversion adapter that can use to reduce installation period. Example from AY81 to QY81P..we can use ERNT-AQTY81 spec.
For AX82, I cannot to find out the the conversion adapter, any one here have experience convert this I/O card in short time during installation stage?
Really appreciate for any reply..
Hello zai_jnr
I have done A to Q conversions using the conversion adapter and by rewiring the cards. The conversion adapters saved a lot of time but still use up a lot of real estate in the panel. Re-wiring the cards takes more time but you save space.
I will check my conversion catalog in the morning and let you know the part numbers.
Hello zai_jnr
Hello Critt,
Thanks a lot for your reply..(y)
I'll waiting your info...
Is there a method to converting an old FX2N program to a Q plc? I was thinking I had done before, but when I go to Project/ Change PLC type the...
1,581
I need to convert the program from a dieing A9GT-RS4 to a GT2310-VTBA. I've sucked the old HMI program using GT Designer 2 Classic and have iQ...
1,382
I have a backup program for an old Mitsubishi. Would anyone here be kind enough to open and export my program into a readable format, please?
1,309
Hello! Please could someone help me out with converting the following rung? As a college project I have to replace an old Mitsubishi F1-40MR...
3,543
I trying to convert the Sharp PLC program to Mitsubishi Q series program, but i having difficulty to understand the function in the sharp PLC...
6,014
