Mitsubishi D/a Converter (a1s62da)
Jan 2006
manila
57
Hi guys,
Can anyone help me with my problem? I have a taiwan made machine, with a velocity control drive unit for x and z axis servo motor. The drive unit is controlled by a digital to analog converter (D/A), sending 0 to 10VDC. When this D/A was damaged, I ordered it from the machine maker and only to find out that the part had been phased out. So I tried to replaced it with a mitsi PLC, A1SHCPU with an A1S62DA converter. I had no problem programming the required analog voltage of 0 to 10vdc using a rotary digital switch with 16 selections as a digital input to plc. The analog output for every rotation of the rotary switch is tested and all are ok. But when I connect the voltage output to the fanuc velocity drive unit, it generated alarms TG and OVC. I don't know why and how it happened but I can't operate my machine. Is it my hard wiring problem bcoz i didn't put an smoothing capacitor to the analog output? Or anything else?
Thanks in advance.
James
I'm trying to find the Mitsubishi GOT Converter program on the iQ Works DVD's and not having any luck. Does anyone know where it is or what the...
1,825
Hi all im having a problem connecting my laptop a philips freevents 11NB5800 to my mitsubishi PLC using the prolific usb serial connector. I can...
11,606
Hi, I am using Mitsubishi SW0PC-FXGP/WIN File Converter (R004) to convert MELSEC MEDOC to FXGPWIP, but for converting the same require *.tmp file...
6,294
has anyone ever used a usb to rs-232 conveter for a mitsubishi series A1-sh plc i get a error of a connection speed not matching and is timing out :(
6,226
Could anyone tell me where i can purchase a SC-03N MITSUBISHI CONVERTOR (at a reasonable price or cheaper equivalent),its for programming a A1SCPU...
4,318
