Mitsubishi E900 HMI issues
kevbloke
Jul 2004
Kent uk
81
I have a E900 which I have been making adjustments to for a couple of hours today. It has been no bother, transferring the project about 5 times until now.
It shows me the start up screen but now doesn’t switch to transfer mode and actually won’t move from the start up screen using the buttons.
I have checked that all relevant settings are correct i.e. Baud rate and Automatic RUN/TRANSFER switching.
The screen has been re-booted several times but is still stuck on the startup screen. Any ideas please.
Is there a manual overall reset button on the HMI that I have missed?
Regards
Kevin
Well i dont know the answer to your problem,
But i have had some strange behavior when i download only the block that i changed.
But after "Send complete project"
It looked as it should.
Maybe worth a shoot
Many thanks for your help chaps. It was Backspace + F22 that done it.
That sheet is well worth having, cheers Bryan.
Hi It maybe a long shot but a customers E900 hmi has gone down, they have a spare but we don't have the firmware to flash it to v6.1. Does anyone...
1,875
Hi, I see everyone of you in this forum have much knowledge about plc, and I'm very new in this things. Maybe someone willingly will help me out...
1,454
Hi I`m new here i`m having some issues with a E900 terminal made by beijer . It is currently sat on firmware version 4.01 everytime i try to...
6,276
U
Does anyone know how to install a backlight on a mitsubishi e900 terminal. If so, do you know where I can get a manual for the mitsubishi e900.
4,171
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
52
