Mitsubishi FX3G-60M and Keyence ML-Z9600 Marker
asteroide
Jul 2010
der
158
Hello Friends
I need to communicate these devices.
Is it possible? How can I do that?
The marker supports RS232C and Ethernet, which could be better with this plc?
Do you have some sample program?
Thanks in advance
Not sure if the FX3G supports the ethernet card i.e. ENET, however, I believe it can use the RS232-BD board, this gives you a RS232 port, it's default setting is for programming protocol but can be set for ASCII coms (if that is what the keyence uses). You set it up in the PLC parameters for example Channel 1 set for non procedural & set the baud rate, chars, stop bits etc.
You need the manual ideally to see how it works. Attached is a simple project & info on 232 coms.
Please note: this is for FX3U but it applies to all FX.
Evening all, Currently stuck in the office trying to get a working bit of program together for a Mitsubishi FX3G to control two FR-D720S...
1,683
I have a client with a Mitsubishi FX3G-60MT PLC the machine is Chinese only 5 years old and surprisingly its build is good. however.... its PLC...
3,383
Hi all, I am totally new to the PLC world and I already face a major obstacle :) I am trying to control a really simple pneumatic system using...
1,462
What cable do I need to connect to a Mitsubishi FX3G? Which program do I need to use, I have the IQ Works package which contains several...
2,841
I have encountered in machine, from China, Mitsubishi PLC FX3GA. Here in Europe I can buy only FX3G or FX3GE (ethernet version) PLCs. I will...
2,550
