I have another problem with a only slave profibus, like in an old topic : the profibus diagnostic it's all ok, i don't have any error on the bus, like in the buffer, but also i don't have any data on the register BFM of the modul DP Mitsu, but only for one slave on 5 connected.
My profibus net, have 5 slave, one PLC B&R X20 (tramissionOK), one ET200S (trasmission OK only with digital signal), 2 drives ADV200 Gefran (trasmissionOK) and a gateway Peppelr WCS PG210e used to read an absolute position. This slave, don't give any information about its status on DP, but it isn't in error.
Wih the same configuration connected at PLC VIPA Speed7 315 (like master), for all test, it's all ok, i have all information from Pepperl gateway, that have the same fuctionality like Mitsubishi.
I tryed to connect only the gateway on the net, to change the number of Id in profibus, to change the speed trasmission, to change some configuration of GSD file, but nothing.
Now i suppose, like Lika encoder profibus, the master Mitsubishi or cann't understand the information from gateway or the information it isn't in the BFM correct, because i have no more test to do.
Some one have the same problem eith FX3U DP Master ?
Bye
Bye
