Mitsubishi Gppw Software with USB port Interface
forever
Mar 2004
Hi, Does anyone know for Mitsubishi Gppw Software, can it support USB port ? As my new laptop does not have serial port only have USB port.
I purchased an Omron USB/232 converter that has worked very well with everything I have tried it on, so far.
The other thing I like about this device is that is has transmit and receive lights. You can see what is going on. Most usefull, not cheap though.
By the way I am running XP Home on a HP laptop. I have successfully connected to Omron C200H - C200 Alpha - CPM1A - CPM2A - ZEN - screens - CS1 - CJ1 with Syswin - CX-Programmer 4.01 - NTSE 4.6 - NS Designer 5 - Device Net Configurator, Hitachi EC with ActsipE - H series with Actsip H and Actwin, Mitsubishi with GX Developer, GE-Fanuc 90-30 with Logicmaster 90, Schneider Twido and smart relay, and several other brands so far. Had to change the com port number in Device Manager as some programs will only recognise coms 1 & 2. Have not been out to service an AB with the new setup yet but it will come shortly I am sure.
beerchug
Bob, can we consider this the 'report back' you mentioned in THIS POST?
If so, could you please add it to that thread so it gets included in the 'works/doesn't work' list?. A simple cut/paste of what you wrote above will suffice... :nodi:
I'm just hoping to make that thread a sort of 'mini database' we can point to when questions like forever's appear... ;)
beerchug
-Eric
Fair enough Eric. Will do.
I guess the problem is that this particular issue turns up many times on several websites. I am getting old and suffering from "old timers disease" and miss them sometimes.
Hey Phil, why don't we have an old timers disease smiley?
I guess this is close.
šŸ™ƒ
Thanks, Bob!... (y)
beerchug
-Eric
P.S. Here's the closest 'old timer's disease' smiley I could find for you -->
I have GPPW Misubishi software. Is there software available that will interact with this when running a programme so you can see how your...
2,448
Can anyone explain with the aid of a ladder diagram how to enter a subroutine into a programme. The plc in use is a FX1n. Thanks.
2,950
How do you enter a subrotine command using this software. Does anyone know of a user friendly book for this type of software.(GPPW) Is the command...
2,632
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
55
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
51
