Mitsubishi GXWork2 Question
jimtech67
Jun 2002
New Jersey
507
I am using Mitsubishi GXWorks 2 with a FX3U
I must make additions to a program that is not documented very well.
Is there a way to tell which bits & word are used ??
I am looking for something similar to the usage button in RSLogix data windows.
Hi jimtech67,
What is it, that is not very well documented?
Is it the systemregisters you have to use?
You can use symbolnames for your variable and when declaring them you chose what kind of type it should be eg. BOOL, INT, WORD, REAL etc.
What manual have you been reading?
/Dariusch
A lot of the D & M (mostly M) registers do not have descriptions attached to them.
When I add a bit or word I do search to make sure the register is not used.
The used are registers are all over the place.
I am looking to display if register is used or not.
Hello,
If you go to the find/replace dropdown there is a device list option. The device list will tell you if the item is used as a contact, coil, or in the parameters.
Obviously if there are no comments associated with the item you won't see anything in the comment section.
Hope this helps,
Dave
THANKS !!!!!
That is exactly what I am looking for.
New again to Mitsubishi, last time I touched one was over 10 years ago.
Manual is huge and clunky with a lot of setting.
Its hard to find the simple stuff sometimes.
Hi jimtech67,
Sorry, I read your post wrong..
Se attached.
Go to "Find/Replace" -> "Device List"
And about the help. There is a good help file i think ;-)
/Dariusch
Aha Dploof23 was responding.. but anyway
hi all, good day to you... im new with plc program, and im facing some problem... im using gx-work 2 (simple project type) , Q00cpu 1st- how...
3,183
hi all, I'm wondering if anyone has ever converted an Allen Bradley AOI to a Mitsubishi Function block. I's hard to find libraries from...
23
149
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
69
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
70
