Mitsubishi MR-J2S-10B
mike63
May 2008
Dublin
Hi all,hope someone can help,have a servo as mentioned in title ,replaced back up battery and about 36 hrs later got an alarm (code 92) battery voltage lowering , replaced battery again with another new one dates goodon battery,again alarm reoccured after about 12 hrs,servo was then replaced but again after about 12 hrs alarm came back ,have checked all connections,any ideas ?????
Battery is used on some servos (including Mitsubishi MR-J2S) to power encoder when machine is shut down. This permits use of quadrature encoder as an absolute position feedback (encoder runs on battery and keeps track of position during power down). If the batteres get drained too fast, check for any leaks. Measure battery current draw without encoder cable connected (any leak in the drive?), then with drive and cable only (leak in cable) and then with motor connected. Consult manual or manufacturer for normal value...
Iam facing a problem with mitsubishi servo drive model MR-J2S series, it's a cut to length application. (Pouch cutting machine),Machine was...
1,311
Hi guys, Any one know about this PLC, please let me know. I am interested in how to reset the dynamic breaking of Mitsubishi Servo motor. Best...
1,394
Hello, I have Mitsubishi MR-J2S-100A4 ("new" from box, not connected anywhere) I'm trying to test it, but after I connect +24VDC it shows...
1,869
I have replaced a drive a Mitsubishi MR-J2S-40A servo drive and now the servo is going in the wrong direction. instead of editing the code, i...
3,453
Hello! I have a Mitsubishi MR-J2S-100A, but I don't now what the input power should be. One the plate: INPUT: 5.0A 3PH+1PH200-230V 50Hz...
2,872
