Mitsubishi PLC Scan time calculation
If your code is done then you could look at a special register (refer to manual) where one can read out last scan time..
If your application isnt done then refer to manuals and count each of the functions you use in the manuals there should be how much time each instruction adds to the scancycle..
I know that an Allen-Bradley PLC will scan every input first and store them in memory, then solve the ladder, then update the outputs. I'm...
4,554
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
131
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
94
Hi all, anyone does have experience in Gx Works 2? Currently I having an issue which is when certain device added from MELSOFT Navigator and...
115
