Mitsubishi Q04UDEH Download Error
asterof
May 2007
Califonia
554
Mitsubishi is not my main cup of tea
DX 2
Have a program with 2 programs on scan and 7 programs on wait, that I can download with no errors
If I add an empty program and set to scan, and try to download
I get Error
"exceeds capacity of the specified drive
Check drive capacity then execute again"
I am sure I have added programs to other Mitsubishi PLC's
Can figure out what the problem is here
Did you check that you are writing to the processor memory and not a memory card? Also you can try to clear the memory (There may be old code in the memory) to reset to factory original and then download program(s) and parameters again.
Did all that
Then downloaded with out new empty program
No Issue
However, I did a free space volume, and it was 163840 before download and 460 after download
So I think the issue is I am out of memory
Whats the easiest way to increase memory
When downloading are you only writing parameters and program. Do not load comments to the program memory. Comments can go on memory card. Not sure how to add memory other than going to a different plc.
Looks like thay make a
Q06UDEH processor that a direct replacement except it has 20K more memory
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
41
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
39
I'm at a new job as the sole control engineer and trying to piece together where my predecessor left off. One machine I'm trying to get online...
103
I'm looking to get some spare keys for this PLC. Does anyone know a source or have a part number? My searches are turning up nothing at the moment.
77
