Mitsubishi Q2ASH CPU Error 2401 File set error
LLIyPiK
Feb 2017
Vinnytsia
Hi to all!
Has anyone encountered such an error? What could be?
Error code list[Error code 2401]
Applicable machine QnA series PLC
Error code(SD0) 2401
Error message FILE SET ERROR
Common information(SD5-12) File name
Individual information(SD13-20) Parameter No.
LED status(RUN) OFF
LED status(ERROR) Flashing
PLC operating state Stop
Diagnostics timing At power ON & reset
Error description & cause
File designated for the fault history file (PLC RAS parameter setting), etc., cannot be created.
Corrective action
Read out the error individual information to a peripheral device, and check/correct the drive name and file name corresponding to that information(parameter No.)
Check the memory card’s remaining memory area.
Sounds like you are trying to create a file in the memory and there is not enough spare memory to create it, perhaps you have done this by accident
33
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
59
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
56
64
I'm at a new job as the sole control engineer and trying to piece together where my predecessor left off. One machine I'm trying to get online...
113
