Mitsubishi q64ad
PLCDUMMY
Oct 2010
NEWBURY
Morning guys,
I have been trying to work out this unit for some time. I just can`t understand how to wire the sensor from Mitsubishi`s diagram. Using 4 wire analog proximity switch.
1. brown
2. blue
3. black - voltage
4. white - current
Wewish to use the voltage function.
as far as the sensor connections
Blue = -ve
Brwn = +ve
WHte
Blck
the wiring depends on your requirements
Thanks Ian,
That`s the drg i could not understand, it`s poo. Wev`e worked out that the sensor is powered from an external supply and the return voltage is compared against the 0v.I`m a mechanical guy and can`t say that in electronics jargon.
the DWG 5.2 is a little complex.
it depends if you use a Current Analogue device or a Voltage type.
please send the sensor details
The analogue output type is not clear in this post
Hi Ian,
We have got the variable voltage working, just waiting to set up a rig on the bench.I don`t want to mess up a working machine. Next challenge is to extract the data.
Hi, i wish to connect a two wire pressure transducer to a Q64ad-gh analog card, i have checked the manuals and even though it doesn't specify 2...
4,416
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
59
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
56
HOW to communicate with OPTIX and Mitsubishi's Q Series PLC?? PLEASE HELP ME
64
I'm at a new job as the sole control engineer and trying to piece together where my predecessor left off. One machine I'm trying to get online...
113
