Mitsubishi servo motor upgrading mrsd-60
sttchui
Mar 2008
kl
81
i have 8 servo motor(mitsubishi mrsd-60 model) connected to ac servo motor(ha-sc63bgy & ha-sc633by) control by misubishi a-series 8 axis servo module card
the problem is the servo driver have been absolute, so i planning to upgrade the servo driver,without changing the plc or the ac servo motor unit
any suggestion what kinda drive i can replace for the current one without major changes on the plc program or hardware
thank you!
SOME MORE ADDITIONAL IFNORMATION REGARDING THE CPU & MODULE I USED!
The servo drive
CPU: A73CPU
Positioning module: AD70D - (control 2 servo drive unit)
Positioning module: A70SF - (Control 8 Servo drive unit)
Servo Drive: MR-SD60 - 10 PCS
Servo Motor: HA-SC63BGY -5 PCS
Servo Motor: HA-SC633GY -5 PCS
The purpose is for the drive unit pick & place part
WHAT IS THE PROGRAMMING SOFTWARE I NEED TO ACCESS THE PROGRAM CAUSE I BEEN READING THE MANUAL, GPPW DOE NOT SUPPORT A73CPU?? IS THE DOWNLOADING CABLE SAME FOE THIS CPU SC-09?
THANK YOU!
Was wondering the two black wires that come from the break on the servo motor for it to work is it all you have to do is add +24V and -24V for the...
1,253
Hi All, If anyone have experience with servo motor driver schneider LXM26D with FX3u-64mt.
1,294
MITSUBISHI FX3S SERIES PLC TO RUN SERVO MOTOR ?? I have FX3S series PLC which have two axis control. I have application to run only in forward...
3,992
We have Mitsubishi HC-KF13 model servo motor and MR-J2 SB drive arrangement in a automatic cutting machine. It dives down with cutting saw and...
2,193
Hi gurus, I have my first encounter with a servo motor yesterday (a milestone). I was task to add the 200W, 3-P motor (HC-K series w/ amplifier...
2,392
