Mitsubishi to B&R RIO through Profibus. Byte problem.
SandstromDJ
Jan 2016
Finland
Hi all.
Long time reader, first time poster.
I am tasked to make a couple of module specific function blocks for communication between our Mitsubishi PLC (GX IEC Developer 7.04) and a B&R remote IO over Profibus. A number of these blocks would then be used, depending on the RIO setup.
Reading should be straight forward, just read X amount of words, starting from address Y.
Writing is trickier as Mitsubishi prefers 16/32 bit Data whereas B&R batches Data in bytes!
As I have several output modules in the RIO. I need to send my info "chained" together.
Example:
Module 1: 2 Bytes
Module 2: 3 Bytes
Module 3: 2 Bytes
Totals: 7 bytes or 4 words.
Sending the first word is no problem. Neither is the next two words (I will just have 1 empty byte at the end of the third word). But then the info to the third module should start in the middle of the third word.
Any idea how I could solve this?
Experimental: At the moment the blocks have inputs (bits), which are stored to a bit-array inside the block and then linked to an output. My idea at the moment is to merge all module-wise output bit arrays to one big bit array, converting that to INT and sending it off to the Profibus address. But I have not yet found a way to merge the arrays and shift them so all data is where it should be.
Above example:
ARRAY [0..15] OF BOOL
+ ARRAY [0..23] OF BOOL
+ ARRAY [0..15] OF BOOL
Totals: ARRAY [0..63] OF BOOL
or [0..71] counting the spare byte.
Converted to 8 Words and forwarded through Profibus.
Thank you in advance.
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
51
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
43
I'm at a new job as the sole control engineer and trying to piece together where my predecessor left off. One machine I'm trying to get online...
109
I'm looking to get some spare keys for this PLC. Does anyone know a source or have a part number? My searches are turning up nothing at the moment.
81
