Mitsuibishi interface module
karl84
Jun 2008
black notley
32
I currently have a Mitsuibishi FX 1N 40MR ES/UL PLC, what i hope to do is to intergrate it with a PC. The task of the PC is to generate 12 random outputs which will inturn send an input to the plc. As that is the task i wish to perform i just need the correct interface module to go with it. I need to have a module that will support 12 inputs to the plc via the pc. Any information you could inform me with would be much appreaciated.
Souds like you want a PC to emulate another PLC and generate hardware signals only to activate a real PLC physical inputs.
What for? Can you provide more details?
added details to thread
I have a PC which is generating random output signals which i need to then input a signal to the PLC, as you (Sergei Troizky) stated on your reply. The task it is to perform is for an exercise machine which will randomly display LED's which are target displays, as well as generating one of four pneumatic rams at any given time. I hope this is of more descriptive.
I think we need more information about the signal generated by the computer -- are they 24 VDC signals? What's their frequency? Is the PC card sending a Source or Sinking signal?
Trying to communicate A series Mitsubishi PLc(25 pin female connector) with Delta HMI(9pin female), on RS422 communication. i tried several...
552
Hi all, I'm experiencing an interesting phenomenon and was wondering if anyone more wise than me could explain it. I'm running a trial of...
1,346
Hello world! The company I started working for has these valves that they ordered years ago as spares. now we have to add couple valves on...
199
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
845
Does anyone know why the connection interface is greyed out and says why I can only use Teleservice instead of the other options like PN/IE? I am...
231
