Mixing Servo Motor and Amplifier Vendors?
sbaum
Mar 2009
Ontario
205
We have a system using a Omron G5 Servo. The motor has failed and Omron has advised the delivery time 4 months for a new motor!
I'm not overly familiar with servo systems and vendors. Is it possible to purchase a servo motor from another vendor to get this machine going?
The servo amp is a Omron R88D-KN50F-ECT which is a 5kw 400V EtherCAT driver.
I don't know much about Omron, but every other servo vendor I have worked with accommodates 3rd party motors. The exception is Yaskawa. The biggest thing is getting the feedback to match.
It is rare for a servo motor to fail. How did it fail? Bearings? A motor shop that works on servos can do certain repairs.
G5 servos are Panasonic. Perhaps they can help.
Thats good to know. I think its bearings so yes we are going to see about repair and also they need to address the mounting as the motor is only 3 years old so obviously there's a radial or other misalignment taking out the bearing.
HI, In a mixing vessel tank, it was maintained with a product temperature of 70 degree. When vacuum applied to the tank, the product and jacket...
27
5,298
Hi all, about to set up a flow loop in our garage that will be mixing oil and water for some water cut testing. In the past we've basically put a...
1,489
Hello This is my first post on this forum, so bear with me. I'm working with a DeviceNet system where there needs to be a transition on the trunk...
2,509
Is it against code to mix voltages within one force guided relay? I have a force guided relay with a 24 VDC coil. This relay has five normally...
3,621
Hello all, I am doing the control system of an asphalt mixing plant. The aggregates is a mix of 5 diffirent ingridients. My question is about...
4,806
