Modbus 16bit uint to rslogix 5000 int
cstep7263
Dec 2019
Katy, TX
35
Hello,
I'm using Compact Logix L33 in RSLogix 5000. I'm trying to message over modbus register that is 16bit UINT. In Rslogix 5000 do I message everything to a tag tat has a data Type INT and then copy it over to a dint? Or Do I leave it as an INT? No registers are over the value of 16,000. Do I loose any resolution if I Message everything over as a INT?
Hello,
Bit patterns for signed INT and unsigned UINT are identical for all values between 0 and 32767 (32k), so with 0-16k it should be fine. The only possible issue would be byte order, but maybe Modbus takes care of that internally?
Good question on the bye order. I do need to know if the byte order will be shifted.
Actually you do not need to know that now, because there are only two possibilities: it's either swapped or it's not, and it is not worth the time to figure out which it is a priori.
TL;DR
Once I realized the above was true, I never worried about it. I set up a test where I knew what the integer value should be from the source, and ensured that the 2-byte integer had a different pair of bytes. If the transferred result was not exactly the same at the destination without the swap, then I swapped the bytes, and the final result was always correct.
I've applied this method on everything from two-byte integers to 8-byte IEEE-754 floating point values to 6x6 transformation matrices. It has not failed me yet: it is always easier to learn and extrapolate from a small set of actual data than it is to try to anticipate those data from manuals; CPUs, serial connections and networks are too stupid to lie; manuals often do.
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
222
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
164
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
48
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
255
