Modbus Communication via Siemens CP343-1
pauly
May 2002
South Wales,U.k
244
I am trying to set up communications between a Siemens CP343-1 module and a DCS. What do the terms client and server mean in the Siemens manual compared to the more traditional master and slave Modbus modes of operation? Also I am not sure how or where to declare the DB's in the MODBUSCP FB. For example, if I want to write data the DCS is looking for bit type values is registers 40001 to 40013 and integer type values in registers 40101 to 401017 how and where do the DB's get declared
Any help is appreciated
I do programming in GX developper for ABB drive model ACS 550 control via modbus communication in FXCPU PLC,I can read the Data of drive...
3,231
Hi everyone! I'm working on a project where I need to communicate a Quantum with a RX3i PAC. The only available driver on the Unity Pro v2.1 (used...
2,940
Hi! I have a S7-1200 1214C with RS232 Communication Module (CM1241) as Modbus Master I found an example of work with MODBUS in here...
4,417
Hi friends; i want to make a PLC based industrial model, using modbus RTU protcol between plc and HMI . Can anyone please help me selecting which...
2,993
Dear all! I am trying to Communicate with one temperature controller(Honeywell DC1040) using Miglogix1500&1769sm2 module via Modbus...
5,715
