[MODBUS] Congrav S
ascoldasice
Jul 2006
tielt
Hey,
I'm currently working on the assembly and programming of an automated reaction vessel. For this vessel I am using an excisting brabender Loss-in-weight feeder with congrav S cotroller. this is used for dosing the Desmodur 15 powder i need.
My problem is the next:
I'm using a CPU313C 2DP PLC from siemens with a CP341 module with MODBUS driver. I learned some S7 programming at school but I have no idea on how to begin on this problem.
i need to be able to change the setpoint in the congrav s module, start and stop the weighing through the MODBUS interface.
here is all the information I have:
the weigher:
http://www.brabender-technologie.com/mainpage/werknorm/english/h32ddsre.pdf
the congrav S module:
http://www.brabender-technologie.com/mainpage/werknorm/english/con_s_e.pdf
the congrav S telegram description:
http://aao.ultis.net/MODBUS/
could anyone plz help me? and give me and example program or explain it to me clearly...
tnx
Ascoldasice
58
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
240
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
177
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
48
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
225
