Modbus mapping and Quantum PLC
pauly
May 2002
South Wales,U.k
244
I am looking to connect a Quantum PLC to some controllers via Modbus TCP/IP. The controller data mapping document shows one of the registers I am interested in is 41001. Does this mean that by default I need to be looking at %IW1001 in the PLC? I think I am looking in the right area of Unity Pro, the Communications tab/Networks, I believe I need to configure something here. Any advice appreciated.
40000 registers are the same as %MW, 41001 should be in %MW1001
I say 'should' because it depends on the plc and drivers etc, it could be in %MW1000. %MW is normally 0 based while 40000 style is 1 based
hope this helps
Hi all, I'm really new to this. I need to export the Modbus register mapping from a Modicon M580 through Control Expert for the registers that...
973
Could someone help me understand how the modbus mapping is handled for the MotionWorks IEC software? I have an existing application where I have...
1,125
I've got a project which requires some Logix integration to a Danfoss device. It is the controls part of an Integrated Technologic Sensorless...
2,937
Dear all, In CCW modbus Adress mapping where each adress is configured in modbus mapping option.For example I will be mapping some memory bit or...
2,137
Got a 2080-LC30-24QWB with 2080-SERIALISOL card hooked up to a Modbus slave device. MSG_MODBUS instructions are working fine. I am trying to set...
3,736
