MODBUS MASTER/SLAVE PCS7 9.1 SP1
Since you have the 5H bundle, you will need to purchase the redundant Modbus license from Siemens. There are special blocks included in the software media kit. You have to enter in the information from NetPro, I have always used PCS7 as the Master, so you need the Netpro ID, the DB for the data, etc.... It is very easy, when you use the blocks from Siemens. For high availability you cannot use the standard methods.
I could not use Modbus RTU freeport Using Fb640 and fb641
Hello, I am quite new to PLC programming. The master would be a Beijier HMI (iX T12B SC) and the slave a Beijier Nexto (XP340). I have...
3,238
I successfully got a Micro 820 (Slave) and Red Lion HMI (Master) to work together using Modbus TCP. But now I need to add an Automation Direct...
2,659
Hi, I need to read from my PLC which is Modbus TCP/IP Master one Siemens S7-1200 PLC which is configured as Profinet IO Device. I know what are...
3,151
Hi All, I'm seeing Point To Point for S7-400 Master/Slave Modbus RTU connection. How can I do RS485 multidrop using CP 441-2 and Modbus driver...
1,296
Hi there, I would like to use an S7-1212C to act as both a Modbus TCP Client and server at the same time. I'm gathering data from generator sets...
1,357
