Modbus motor speed control
nosajnil
Apr 2017
USA
20
I am trying to have user start/stop and change motor speed from a touchscreen. I attached a table that was given from the motor manufacture. I am a bit lost which MODBUS block I should use in Cscape (PLC programming software), and what I need to put in those blocks. I would appreciate a lot if someone can point me to the right direction.
So I figure out how to open the comm port. but now I am not sure how to send commands to a slave device. I have tried in the attached screenshot (which I am sure it I am doing something wrong, but would like you guys to guide me in the right direction).
Where do I put the 40001~ 40025 register address? and what does it translate to in Cscape? (%R, T, M etc address?).
Where do I input value? (0 for motor off, 1 for motor on, 0-100 for speed etc).
I am only testing for now and each value is selectable from the touchscreen. (I labeled on the screenshot as 1 to 7)
should they all be 16 bit?
I am wanting to display the ac motor power being generated by an AC Inverter. I have successfully created a modbus network between a Micrologix...
19
9,765
Hi all Please help me on the following issue In my system I have a Quantum PLC with NOE card connected to MNS iS Motor Control Center (ABB...
6,306
Hello Everyone, I am using a raC_Opr_NetModbusTCPClient AOI module, as below,. So, I need some assistance to restrict in reducing the poling...
110
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
76
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
341
