Modbus RTU Accepted No Response / Timeouts Percentage
69FIREBIRD
Oct 2004
New Zealand
102
Hello, I want to find some documentation/standard on accepted percentage of no responses/timeouts. i.e. is 1/100 1/1,000 1/10,000 1/100,000. I had a quick skim through modbus.org documents but nothing stood out.
I have a network where there is an issue with proprietary Lighting Controllers not responding to commands from my 1756 Prosoft Master. I know why its not responding (-11 response code) and this is a bigger issue related to the Lighting Controller hardware/firmware and passing on commands "downstream" to the light fitting installation over powerlines.
We are able to insure a command does gets through by tuning up timeout time, time between commands and retries and because we're dealing with gradual lighting changes its not a big issue.
I have a colleague who says 1 timeout/no response in a year is not acceptable in some industries and in his case this generates an alarm condition. Personally I think this is excessive, so finding some documentation that defines acceptable percentages for my recommendations would be great.
Thanks for the feedback in advance.
Your colleague is smoking crack. Some instruments will have no misses but others are almost guaranteed to miss messages. I shoot for <1% but sometimes have to accept as high as 3-4%. Some instrument manufacturers just suck at implementation and it can't be helped.
I still have some old MB+ networks. If there are more than 2 retries in a month I go looking for a fault.
But it's horses for courses really. If you were using modbus over radio then you'd tolerate 98% success rate in a day.
So the answer really is... it depends.
Will the dropped messages affect operation? If not, then establish an acceptable base line and at up an alarm if that is exceeded by more than say 5%.
Then look at resolving why you're getting an error by talking to the equipment supplier to sort their issue out.
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
48
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
256
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
114
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
485
