Modbus RTU <-> ASCII
mareki
Jun 2002
Hello,
How can I convert signal from Modbus RTU to Modbus ASCII. I know that I can make it using computer and simple software, but I need more safety solution.
Is anybody who can help me?
Best regards
mareki
There are companies like Pro-Soft and Phoenix that make various communications bridges. Contact them for assistance. If they don't offer the product, they may be able to recommend a source.
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
60
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
260
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
286
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
121
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
544
