Modbus RTU from control logix system
srv
Aug 2010
QATAR
109
We have a control logix system in an existing old plant.Now we need to connect a RTU to this system to transmit some datas from the PLC.I think modbus is the only way to connect RTU to control logix plc.Do we need to add any PLC code in the plc to establish modbus communication between PLC and RTU.which port we can use for communication.ethernet or Serial port ?
99% if the time I do NOT use the serial port on the PLC. You can use the native serial port on some units. I would add a Prosoft card to the chassis.
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
48
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
223
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
258
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
116
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
498
