MODBUS RTU testing program
naturephoenix
Jan 2015
Vienn
181
I got S7-300 and CP (CP 341 -RS422/485)[PLC should be MASTER] and on middle voltage device SEL-787 which should be a slave.
I'm still waiting for SIEMENS equipment to arrive, but slave device (SEL-787) I will not have before commisioning.
My question is how to test my program
Option A:
1. Without any single device Master nor slave
Option B:
2. With Master equipment (S7-300 and CP (CP 341 -RS422/485)->6ES7 341-1CH02-0AE0
Communication processor with connection: RS422/485 (RK512, ASCII, 3964(R), printer, loadable driver)
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
60
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
260
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
286
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
121
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
545
