Modbus RTU to Modbus TCP Gateways
Count Zero
Sep 2022
San Diego, CA
Looking to purchase some Modbus RTU to Modbus TCP gateways and was curious if anyone had any recent experience with specific brands they could share good or bad.,
AutomationDirect gateways are generally solid.
Using Rockwell's Modbus TCP AOI on pretty much any 5370/5x80 works to this end (their artificial memory contraints permitting).
Ive used several different units over the years. Some are good some a bad. It depends on if you need anything other than just point to point conversion.
If you need more than just conversion Redlion is my first choice.
If you just need conversion Real Time Automation is my goto.
Netbitter, ICC designs, MOXA, ProSoft are a few that I can think of that Ive used .
I stock a RedLion DA30 because it will do so much more than just gateway conversions
If have 4 Automation Direct Modbus Gateways installed, working well, easy to configure. Part number is MB-GATEWAY. these do 422/485 not 232.
If you are looking to do RS232, GridConnect has some low-cost options that perform very well.
If you need RS232 and more than one device, Digi TS(1,2,4,8) are good, but more costly.
RTA Automation one are very easy to use, web page setup.
I also recommend Spectrum Control's Universal Gateway, again, easy web page setup.
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
51
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
228
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
268
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
116
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
512
