Modbus RTU - VersaMax - Yokogawa CS3000
fujiyamoma
Jun 2008
Philly
Hi!
I am trying to get Modbus RTU communications going between a Versamax PLC and a Yokogawa CS3000 ALR121 card by way of a 4-wire RS485 link. I have the pin fan-out correctly set for the VersaMax and the 5 wires on the terminal on the CS3000.
9600bps, even parity, 8 bit, 1 bit stop, no error detection and I can't seem to get any communication link between the two. I have the 120ohm terminator on the RXA/B set up for both.
Anyone might have an idea of what I can use to determine if the communication is happening but somehow timing-out, some box/device with LED or something to see what turns on/off, and maybe some insights on speed (9600 bps might be too slow or too fast). We tried 1200 bps it did not work either.
The cable I use is a CAT5e cable patch cable, cut on both end and I used a crimper and crimped pins for the DB25 connector for the versamax.
Thank you in advance for any clue you may offer.
Dear Experts, I am new to the GE Fanuc systems, I need some guidance in communication between RX3i PAC system (CPU CRU 320)and Versamax CPUE05...
4,552
Hi, I am trying to communicate with a GE Micro-Versamax PLC. My configuration is as follows: - Digi SP one connected to the RS-485 port of the PLC...
7,681
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
48
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
256
