MODBUS RTU - will it work on this way
naturephoenix
Jan 2015
Vienn
181
Hello,
We had CPU ET200s (6Es7 151-8AB01-0AB0) and ET200S 1SI Modbus CP MLFB No. 6ES7-138-4DF11-0AB0.
We were modbus master and all worked fine.
Now we have to change PLC, instead of Et200s we gonna put CPU315-2 PN/DP.
Since we have to change PLC, if we add also distributed module for ET200s ->
6Es7 151-3AA23 - 0AB0 and put
ET200S 1SI Modbus CP MLFB No. 6ES7-138-4DF11-0AB0 on it will MODBUS RTU - will it work on this way with the same code that was running on previous configuration:(We had CPU ET200s (6Es7 151-8AB01-0AB0) and ET200S 1SI Modbus CP MLFB No. 6ES7-138-4DF11-0AB0.) with FB2 and FB3 functions.
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
51
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
229
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
271
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
117
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
515
