Modbus S7-1200 Siemens Example Query
504bloke
Jan 2005
Down South
2,721
Hi All
If you look here at the siemens example
https://support.industry.siemens.co...rtal)-for-the-simatic-s7-1200-?dti=0&lc=en-ZA
I had a read and then started my own read/write
My question is in siemens example in the DB's there are DataTypes of "type" (see pics) - If I put the datatype into my own code its red with an error - what is the type and how do I establish this - I have had a god look and cant find anything to help
Hello.
It's a user defined datatype.
You can create your own dataype that matches the one in the example.
Go into the "PLC data types" folder of your project and create a datatype.
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
267
I have 3 control panels made by an OEM, they are all identical and have a Siemens S7-1200 PLC with a Siemens CB-1241 Modbus card talking to 2...
4,562
Hi All, I have a closed loop stepper motor (Nanotec make), https://en.nanotec.com/products/2512-pd4-e601l42-e-65-4. This uses MODBUS TCP for...
3,902
Hello; i'm having some troubles with a com test i'm handling. i have another end for it, but for now i would like to have : M241 in io_scanning...
3,496
Hi all, I've hit a bit of a brick wall and need some help. I'm currently trying to get a Siemens S7-1200 PLC to talk to an Eaton DE1 Drive I'm...
3,691
