Modbus TCP diagnostics
manin
Jan 2015
Athens
37
Hello, I am building an application that communicates with plc through modbus tcp.
I can read registers and coils, with all commands (1-4).
My problem is that I have not found a way to get diagnostics messages from plc. Modbus_TCP_Standard refairs in fc 08 command..
My questions are,
1. DOes this commands works really under modbus tcp? Ι read modbus rtu and says that diagnositcs do not work at modbus tcp
2. HAve you any idea, what command should I send to get communication messages ?
Best regards
Standard says fc8 is for diagnostics in vendor specific devices. Does your PLC support this function? Usually no, at least I haven't seen one.
So then you have to program some diagnostics and send the status data in the registers that you can access.
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
100
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
193
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
333
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
522
Hi There. I have PC to get few tags from PLC into C# windows forms application. What is the best and fastest way? I could not find Omron in...
297
