modbus tcp/ip
osama89
Apr 2014
Jeddah
I am working on a project in which I have to use Modbus tcp/ip in s7 300.
my CP is CLIENT and SLAVE is my PC.
until now my parameterization is complete and I am able to write values on SLAVE, but my CP is not reading values from PC.
what must be the problem ... ?
need help ...
đź“š
What type of application is your Modbus/TCP slave running on a PC?
Is it a generic Modbus program like Modscan32 or Modpoll's slave?
Or is it an application involving I/O cards?
Did you write the slave application or is it a commercial Modbus slave?
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
341
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
229
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
349
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
554
Hi There. I have PC to get few tags from PLC into C# windows forms application. What is the best and fastest way? I could not find Omron in...
317
