cjh
When I look at the captures, it appears to me that you are not seeing the traffic between the Micrologix and the Omega controller which would be normal when using a true unmanaged switch. You will need a managed switch with port mirroring capability or a 'true' ethernet hub as Ken stated earlier. The unmanaged switch is filtering out the messages from your PC.
