Modbus TCP Master Simulator
Chuck Hoyt
Jul 2005
Bakersfield, CA
28
Gentlemen,
I have a customer (he tried to register but wasn't successful so I am posting this question for him) that is benching radios and has successfully used a Modbus Remote simulator but was looking for a Modbus Master simulator. He has tried the Modscan simulator and it works just fine for Modbus RTU applications but when he tries to use it as a Modbus TCP master it crashes. Any suggestions out there? Thank you in advance! EDIT: I just found out that he needs to simulate the TCP Master polling a Modbus TCP remote.
Chuck
Thank you so much everybody! I've passed everything on and asked that he let me know which one did the job for his application and I'll let everyone know .
Take care all,
Chuck
I have a Waukee temperature controller that has an internal limitation of only allowing a single TCP master connection. Problem is I need to have...
20
4,854
I successfully got a Micro 820 (Slave) and Red Lion HMI (Master) to work together using Modbus TCP. But now I need to add an Automation Direct...
2,662
Hi, I need to read from my PLC which is Modbus TCP/IP Master one Siemens S7-1200 PLC which is configured as Profinet IO Device. I know what are...
3,151
I just got an IFM AL1343 IO-Link master with Modbus TCP interface From the manual this thing seems to have a Web Interface(http) for view its...
2,121
I have 6 Modbus devices that I need to get communicating with an L72. Rockwell supplies a program that allows one of their controllers to act as a...
2,710
