danw
1. Modbus TCP vs Modbus UDP
There is recent mention of Modbus UDP (Modbus over ethernet, but UDP, not TCP) on this thread.
http://www.plctalk.net/qanda/showthread.php?p=772283#post772283
I found this description on an opensource page:
http://jamod.sourceforge.net/kbase/modbus_udp.html
I have not run into Modbus UDP, but and I'm interested in whether others have and what their experience is.
Does a Modbus TCP server or client care whether the Modbus packet arrives UDP?
Will its response as a TCP packet be acceptable?
In other words, do both ends have to be UDP in order for server/client to play nicely together?
2. Modbus TCP vs RTU (over RS-485)
I prefer TCP because Ethernet (10base T [twisted pair], not 10base2/5 [coaxial]) is inherently isolated and does not require termination resistors or biasing. It does have a shorter distance limitation than RS-485, but with the available plant Ethernet infrastructures, that is less and less of a problem over time. Essentially, plug in Ethernet and if the IP address, subnet mask and gateway are suitable (all configuration, no wiring), the devices talk.
RS-485 is frequently non-isolated, subject to common mode issues, frequently lacks signal ground connections, requires termination, and if biasing is required it is an engineering job to achieve it. It can be a bear just to get 485 devices to talk to one another, even if the cabling distance specs are longer.
