Modbus TCP with Do More PLC, MRX instruction
Jasondelane
Mar 2015
Florence sc
221
I have a project coming up in a few months where I'll be taking measurement from an LMI Gocator and sending them to a Do More PLC H2-DM1E.
I have the Gocator set up on Modbus TCP, and the output is configured automatically as follows.
Command 0 16-bit
Arguments 1 var
Sensor State 300 16-bit
Command in Progress 301 16-bit
Alignment State 302 16-bit
Encoder 303 64-bit
Time 307 64-bit
Job Name Length 311 16-bit
Job Name 312 var
Index 0 375 32-bit
Index 1 377 32-bit
Index 2 379 32-bit
Index 3 381 32-bit
Buffer Advance Register 976 16-bit
Buffer Count 977 16-bit
Buffer Overflow Flag 978 16-bit
Inputs 979 16-bit
zPosition 980 64-bit
Exposure 984 32-bit
Temperature 986 32-bit
Encoder Position 988 64-bit
Time 992 64-bit
Frame Index 996 64-bit
[V] Profile Bounding Box/X 1000 32-bit
[D] Profile Bounding Box/X 1002 16-bit
[V] Profile Advanced Height/Height 1 1003 32-bit
[D] Profile Advanced Height/Height 1 1005 16-bit
[V] Profile Advanced Height/Height 2 1006 32-bit
[D] Profile Advanced Height/Height 2 1008 16-bit
[V] Profile Advanced Height/Height 3 1009 32-bit
[D] Profile Advanced Height/Height 3 1011 16-bit
I'm using a WRX instruction in the Do More, trying to get values from Height 1, Height 2, and Height 3. I'm able to poll and get data from the Gocator, but only certain registers are actually providing useful data.
How should I properly configure the Memory Configuration and MRX instruction to get this data into its own register?
I made a new memory block called SCAN, Signed DWORD and I'm using that as the destination for the MRX instruction.
The MRX instruction setup is using function 3, Read Holding Registers, offset from register 900, for 125 registers, destination SCAN0
Where am I going wrong in this setup?
solved
I figured it out using the SUBSCRIB instruction and different combinations for each word. A couple of them had to be converted differently.
I'm not sure exactly how, but it's working.
Simon was a game that I remember well when I was younger. This simple game can teach us how to program sequencers and look for inputs in a correct...
6,849
Here is a post that I would like to share... Create a PLC with HMI Training and Learning Environment Free Learn PLC programming and use a...
3,000
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
57
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
183
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
326
