modbus tcpip over 90 30
ravindra156
Jan 2016
mumbai
Hi there.
I am developing a logic using commreq for communication between two ge plc 90 30 using modbus tcpip.
i am not able to get data as req.
request to help me out.
also i am not able to attach the file for snap shots of logic.
kindly guide me.
i am new to this forum.
thanks in advance
ravindra
Hi there.
kindly guide me.
thanks in advance
ravindra
You need not attach a file to share your logic. Select your logic in Proficy ME and press Ctrl-C to copy it. Then in this forum paste that logic between the markers:
[ code ] (without spaces)
**your code is pasted here**
[ /code ] (without spaces)
Code:
The information for us to copy your logic into our Proficy  to see will be here.
For Ethernet details Get GFK-2224 from the GE web site.
Generally for CPU to CPU communications over Ethernet I would recommend using EGD, it is much simpler and more efficient in my opinion.
There is Modbus TCP/IP information in this file too.
also i cannot use EGD since one plc is GE 90-30. ic396cpu260
I would on all that I could, and I have never heard of an IC693CPU260. If it's CPU360 with an Etherent module you would need to verify which version of the IC693CMM321 is in it for either MB/TCP or EGD.
But the CMM321 and CPU360 are both obsolete so I would recommend updating that system to RX3i.
Actually, if this system is to be run for 5 years or more, you should put together a plan to update all the 90-30s to RX3i over the next couple of years.
Right now GE has a very good "Trade in" plan to do this, contact your local supplier.
Hello brothers Now I have problem in taking data, I use modscan32 to try to see values from modbus tcpip, for input registers, address 40002...
521
Hi All, We are using M580 Level 4 Hot Standby System. We are using the BMENOC0301 module to do Modbus scanning from the Modbus units (Genset...
2,315
Good day Could somebody please help. I'm sending a position and a speed to a motion task in a Kollmorgen AKD servo drive from a Delta PLC via...
1,336
Dear sirs, Currently i am working on a project which requires to connect the plc ethernet port to monitoring devices, for your information the...
8,028
I'm looking for a cheap way to read modbus TCPIP data into a PLC and fire some outputs (8-10). We bult a unit using a old SLC 500 and a prosoft...
2,232
