modicon 140 ACI 030 00 OVD Terminal Block?
wooley8
Jul 2011
dallas
Hello,
I am new to this forum so i'll start off with a simple how is everyone doing? I am curently trying to connect a 2 wire (loop) powered transmitter to a modicon 140 ACI 030 00 analog input card. All other devices on this card are 4 wire and are powered in the field. It was the only spare A/I point i had so i have to make it work. I/ve found 24VDC power supply and ran it in series with my transmitter. Now i need to know if there is a terminal block on this model card to land my 0VDC wire.
Can any be of any assistance? im trying to do this without having to use anymore space than i have to because there isnt any left in this PLC cabinant so i need it all at the card iff poosible.
This shows for a source powered transmitter. The only difference is you would take +24vdc to the + of the transmitter and the - of the transmitter you will connect to terminal 3. Then take 0vdc to terminal 2. Make sure to keep the bridge between terminal 1 and 3 for current loop.
Hi to all.. We have Modicon Quantum ( 140cpu11303 ), and proworx32. I will try to connect cpu with software , but can't to attach cpu. Note...
3,999
I want to ask that what is the recommended memory that should be used by controller ? in my case the memory is 72 % consumed , which can shown by...
2,335
Hi everybody , I hope all friends in best situation , I needs your help to solve my big problem with Schneider PLC network i working to...
4,886
I am trying to understand how this Modicon Quantum 140 CPU 434 12 actually processes the EFBs. Are they scanned in vertical columns like ladder...
2,573
Hi, I have new Moodicon PLC CPU 140 652 60 and I want to change the IP address, Subnet mask, and the gateway for this plc using the key pad. The...
4,548
