modicon 984-380 plc
ipsbassi
Feb 2007
NY
Hi everyone,
i work in a paper converting faciltiy and we have a machine with modicon 984-380 plc,this machine was shutdown for serveral years and now we want to run this machine,we powered up th e machine and found out plc run led is not lit,while power ok and ready lights are lit green.and none of its output lights are on.this plc has AS-E380-902 Standard 380 Exec Cartridge AND AS-M380-004
4K MEMORY CARTRIDGE,i'm not sure i still have program in it, so what is the best way to find out if there is program in it or how i can put this cpu back to run mode, i don't have any programming software or cable for this plc either. I also found a gould P964
hand held programmer i'm not sure this guy is compatible with plc or will be of any help for me in this case.please advice thanks in advance
I dont know anything about this controller but these links take you to some manuals.
I found this link using google for 984-380:
http://download.telemecanique.com/85256D9800508A23/all/852566B70073220C85256B8A0048AA48?OpenDocument&L=EN
Also google the memory cartridge number AS-M380-004 for more info.
Here is a link for the gould p964:
http://www.telemecanique.com/85256D9800508A23/all/852566B70073220C85256B91007628F2/$File/p964%20data%20access%20panel.pdf
Look at the command section page 6-3 and 6-4 to start(run) or stop the controller.
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
254
Hi I have a modicon 984 with proworx 32 that is scaling an analog input, and I need to adjust the scaling. I have new analog input values and %...
1,737
Hi, I am trying to get a machine started that was moved from one location to another. It has a Modicon 984-A131 PLC. I have Schneider Electric...
1,030
Dear Friends, I have Schneider PLC which is the world's first one Modicon i need software of Modicon PLC 984,it is known as...
971
I found the below logic in an old program. If I am reading the System Manual correctly, it appears that the UCTR will never count up to 10, since...
1,656
